Trying to open up a server on my TeamSpeak, I only have TeamSpeak as its required to participate in certain aspects of my hobby. Every attempt I make to connect to a server, the application closes with no crash report or error afterwards. Need assistance
Try this Version out: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
thank you, will do
Worked, thank you for the help with that. I was wondering if I had to update it or not, now I know. For future reference, do I update the launcher through the application or the website?
If there is a new update in the Client available update it there. The next update should fix the crashes
Hi, I have a problem with Ts3:
Every time I want to connect to a server (any server) TS crashes without any error code, just like when I activate the language test. Otherwise everything works, options etc. The teamspeak client crashes upon trying to open an input device. No error messages or anything. It just crashes silently.
(https://imgur.com/OVN2IU3)
Thanks if someone can help me.
To fix this, please Download this Client: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
Hi, I can’t join any server. After I press connect, it automatically closes right after. I already tried to reinstall it. Please help me
Im on Mac newest version , reinstalled already, no plugins except the automatic one installed
This Version fixes the crash: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
Hello. Please solve my problem. MacOS. TeamSpeak client automatically turn off when I connect to any server. Thank you!
You may need this:
Last login: Mon May 10 12:40:58 on ttys000
/Applications/TeamSpeak\ 3\ Client.app/Contents/MacOS/ts3client_mac ; exit;
maciejkunat@MacBook-Air-Maciej ~ % /Applications/TeamSpeak\ 3\ Client.app/Contents/MacOS/ts3client_mac ; exit;
Crashdump ENABLED, directory is: /Users/maciejkunat/Library/Application Support/TeamSpeak 3/crashdumps
DUMP defined! Dumpdir is: /Users/maciejkunat/Library/Application Support/TeamSpeak 3/crashdumps
2021-05-10 10:41:56.070412|INFO | | |TeamSpeak Client 3.5.6 (2020-11-25 13:53:42)
2021-05-10 10:41:56.070522|INFO | | |SystemInformation: Darwin 20.4.0 Darwin Kernel Version 20.4.0: Thu Apr 22 21:46:47 PDT 2021; root:xnu-7195.101.2~1/RELEASE_X86_64 x86_64 Binary: 64bit
2021-05-10 10:41:56.157672|INFO |ClientUI | |OpenGL Info: LibGL, Vendor: Intel Inc., Renderer: Intel(R) HD Graphics 6000, Version: 2.1 INTEL-16.2.16
2021-05-10 10:41:56.158505|ERROR |RevocationListCache| |Failed to import revocation list from cache
2021-05-10 10:41:56.285464|INFO | | |*** Time [ICONMANGER]: 141
2021-05-10 10:41:56.286493|INFO |Addons | |Checking for addon updates…
2021-05-10 10:41:56.321132|INFO | | |successfully downloaded revocation list for accounting
2021-05-10 10:41:56.351430|INFO |Plugins | |Loading plugin: libclientquery_plugin_mac.dylib
2021-05-10 10:41:56.387064|INFO |Query | |listening on 127.0.0.1:25639
2021-05-10 10:41:56.443406|INFO |Addon | |Addon up to date.
2021-05-10 10:41:56.474209|INFO | | |successfully downloaded revocation list for myteamspeak id
ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2021-05-10 10:41:56.598126|INFO | | |*** Time [MAINWINDOW]: 512
2021-05-10 10:41:56.598273|INFO | | |*** Time [INIT]: 512
2021-05-10 10:41:56.964694|INFO |ClientUI | |Qt version: 5.12.3
2021-05-10 10:41:56.964809|INFO |ClientUI | |Using configuration location: /Users/maciejkunat/Library/Application Support/TeamSpeak 3/settings.db
2021-05-10 10:41:57.207133|INFO |Bookmarks | |Collecting autoconnect bookmarks
2021-05-10 10:41:57.208719|INFO |ClientUI | |Last update check was: pon. maj 10 12:24:12 2021
2021-05-10 10:41:57.209373|INFO | | |Statistics report: Not yet, next report on czw. cze 3 12:34:20 2021
2021-05-10 10:41:57.601879|INFO |Newsticker | |Newsticker next check: wt. maj 11 10:24:14 2021 GMT
2021-05-10 10:42:05.066053|INFO |ClientUI |1 |Connect to server: voice.teamspeak.com
2021-05-10 10:42:05.069743|INFO |ClientUI |1 |Trying to resolve voice.teamspeak.com
2021-05-10 10:42:05.102124|INFO |TSDNS | |SRV DNS resolve successful, “_ts3._udp.voice.teamspeak.com” =(h: dc-9a34d226b974.teamspeak.com p:9987)
2021-05-10 10:42:05.103919|INFO |TSDNS | |SRV DNS resolve unsuccessful, “_tsdns._tcp.teamspeak.com” Domain name not found
2021-05-10 10:42:05.105189|INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, “voice.teamspeak.com” =(h: 104.22.26.164 p:0)
2021-05-10 10:42:05.106863|INFO |TSDNS | |A/AAAA DNS resolve successful, “voice.teamspeak.com” =(h: 104.22.26.164 p:0)
2021-05-10 10:42:05.107255|INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, “teamspeak.com” =(h: 104.22.26.164 p:0)
2021-05-10 10:42:05.139816|INFO |TSDNS | |A/AAAA DNS resolve successful, “dc-9a34d226b974.teamspeak.com” =(h: 2001:41d0:700:1c5c:: p:0), (h: 51.68.181.92 p:0)
2021-05-10 10:42:05.140411|INFO |ClientUI |1 |Lookup finished: ip=2001:41d0:700:1c5c:: port=9987 query=voice.teamspeak.com error=0
2021-05-10 10:42:05.140647|INFO |ClientUI |1 |Resolve successful: [2001:41d0:700:1c5c::]:998751.68.181.92:9987
2021-05-10 10:42:05.140805|INFO |ClientUI |1 |Initiating connection: [2001:41d0:700:1c5c::]:9987
2021-05-10 10:42:05.163416|INFO |Core Audio | |No speakers assigned to channels. Please do this in AUDIO MIDI SETUP of osx. Defaulting to stereo for now failure: (0) noErr
2021-05-10 10:42:05.163993|INFO |Core Audio | |Opened playback device with 2 channels at 44100 Hz -
2021-05-10 10:42:05.165173|DEBUG |Core Audio | |BufferFrameSizeRange = 14, 4096 -
2021-05-10 10:42:05.298583|INFO |Core Audio | |Opened capture device with 2 channels at 44100 Hz -
2021-05-10 10:42:05.298958|DEBUG |Core Audio | |BufferFrameSizeRange = 14, 4096 -
Starting Error Reporter: /private/var/folders/rz/440s8nd55_7cr6qtnbfhyc5c0000gn/T/error_report.sh
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
I have a big problem. As soon as I try to connect to a server my TeamSpeak crashes.
I have an Apple MacBook Pro 2016 which is on the latest version. I have already reinstalled TeamSpeak but it doesn’t work. Everything works without errors but as soon as I try to connect it crashes.
I also do not get a crash report
What can I do and what could be the problem?
Hello, when I am trying to connect a voice chat by clicking connections and connect, when I press connect the application drops and I have to reopen it. Before the app drops it says trying to resolve hostname.
Ok, thanks, I will try it
Thanks, fixed the problem
Works for me as well - thanks!
… should find it’s way in the official update channel
I did the update to Big Sur 11.3.1, but I can’t solve the problem with 3.5.7.
I can’t even access the beta without being put on the waiting list.
Is there any way to solve this problem?
I have a Problem with using Teamspeak 3 on MacOS BigSur on my MacBook Pro (16 Zoll, 2019)
Since January my TeamSpeak keeps crashing when I try to connect to any server.
I have multiple times tried to reinstall it. Furthermore I have reinstalled my device many times and it keeps crashing. Can you help me to fix this issue?
