This Version fixes the crash: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
When I try to connect to the IP it just boots me and says nothing. I have uninstalled and reinstalled which has done nothing. Can anyone help?
Do you use MacOS? If so this Version should fix the problem: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
Let me try this.
It worked thanks!
It worked thanks!
so ii can’t click on any of those links which are posted as potential fixes aswell as TS crashing upon attempting to connect to servers D:
MacOS BigSlur 11.3.1
any ideas?
Try pasting the URL into the search bar.
Got to love how simple a fix can be xD
That worked - mac started getting upset about security checks but otherwise back to work.
Thanks
@alfatrad We have the same exact problem, and the same reason why we singed up here lol
The release version of TeamSpeak also crashes on macOS 11.4, so TeamSpeak has been broken for two minor versions of macOS.
The beta version linked above works great tho, aside from not being notarized! Looking forward to it hitting the release channel.
10000 thanks!! 3.5.5/6 - crushes, and official Russian site give only 3.5.6 :с Try ure version - Work.
Mac Pro M1 - OS BigSur 11.4.
There is no official other site. There is is only teamspeak.com and you are in the forum of that site.
Edit by mod: Post moved
Same happen to me on MacOS 11.4. Never has any pugins:
Delete /Users/…/Library/ApplicationSupport/Teamspeak 3/
Upgrade to latest 3.5.6
Core buffer problem.
After known that. Open Only Teamspeak go to preferences try to test audio. BAM.
Greetings
Andy
resources not found at /Applications/TeamSpeak 3 Client.app/Contents/Resources. Trying parent directory…
Qt WebEngine resources not found at /usr/local/Cellar/qt/5.12.3. Trying application directory…
2021-06-10 08:05:45.998550|INFO |Core Audio | |Opened capture device with 2 channels at 44100 Hz -
2021-06-10 08:05:45.998710|DEBUG |Core Audio | |BufferFrameSizeRange = 14, 4096 -
Starting Error Reporter: /private/var/folders/tr/yyj27gy137n6sc0h6fq85qrc0000gn/T/error_report.sh
So at the moment for me no teamspeak on MacOS 11.4
Hi, i need to help with connection to server. I have Mac OS and download app from official web. When i try to connect to server (i try about 5 different servers) the TS3 always fall down. I try to reinstall it but its still the same. Thanks.
Try this Version: Index
The next major version of macOS has been announced now, and the release version of Teamspeak crashes on the 12.0 betas. I’m still looking forward to the beta version of Teamspeak hitting the release channel and being properly notarized!
Hello, I have a big problem with Teamspeak. When I open Teamspeak on Mac everything is fine, but when I open something with a microphone or want to join a server, Teamspeak closes directly without me being able to change anything. What could be the reason for the problem? I hope someone can help me.
Thanks a lot
Please try client 3.5.7 for testing.: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
@Rikku Confirm this works on latest
- MacOS BigSur 11.5 &
- MacOS Monterey 12.0 (Beta 21A5248p)
Now it asks for microphone and does not crash.
