I can confirm that it’s fixed! Thank you
Pretty dope. I’ll totally add that to my server! Thanks!
Some urls can’t be load because of cross-origin request blocked. Can you do something about it or does the site have to allow it?
Thanks for the feedback!
Unfortunately, this is a limitation of the web.
If a given site does not allow cross-origin requests image will fail to load. Sorry about that, I will add a better error message when this happens to make this more clear.
Looks awesome!
Good Job!
Thank you this is so cool
Cool
Can u also add a horizontal offset for the future?
…btw awesome tool, love it
Nice
Happy to hear that you like the tool.
Yes, basic image manipulation such as Flip, Offset, Scale is planned. I will let you know when it will be ready.
Imgur’s fault.
TeamSpeak requests are blocked by imgur.
You need to use a different image hoster.
You need to use address directly to the image not to the imgur page … so instead of https://imgur.com/5HYPuA3 use https://i.imgur.com/5HYPuA3.png
@Gamer92000 Imgur works fine for me btw… ![]()
thanks it works
Yeah, maybe it works only sometimes. I’d still recommend not using imgur for TS purposes:
so i am done and am surprised how well everything works thanks again for this tool and the help grade
@pitkes22 don’t know if it’s possible, but it would be nice if you could choose which channels are “subs” so you could avoid things like this
Like after setting how many channels you want, then choose which of them are subs and what is their depth(1 until 5 i guess is fine - personally i have max 2-3)
Working on this right now. I’ll Let you know when it will be ready
awesome! Keep up the great work man
