Colors featured in this theme:
Installing the theme
Just extract the Theme folder and drop it into the Extension folder and select it in the settings.
Default Extensions folder:
Windows: %appdata%\TeamSpeak\Default\extensions
Linux: ~/.config/TeamSpeak/Default/extensions
Mac: ~/Library/Preferences/TeamSpeak/Default/extensions
The theme can be activated in Settings -> Apperance -> User Theme
(you need to reload the themes or restart the client for it to show up)
Special thanks to @Gamer92000 helping me creating this Extionsion.
And especially to whole team @TeamSpeak for implementing the official theming engine!
v1.0.1
//CHANGED
//ADJUSTED
Adjusted 4 Colors || TeamSpeak -- Cyan -- Red -- Green
//ADDED
Added 5 new Colors || Dark Green -- Dark Orange -- Dark Red -- Gray -- Purple
Download
The Download can be found as always in the initial post .
v1.0.2
//CHANGED
Cleaned up code
Changed Hex patterns
//FIXED
Fixed Light Mode incompatibility
Fixed Thumbnail miss matches
Fixed Server triangle not connected with the scroll bar
Fixed Recent server event list colors
//ADJUSTED
Adjusted Colors || Dark Red -- Red (second Color) -- Dark Orange (second Color) -- Orange (second Color)
Adjusted the width of the scroll bar to improve the tangibility
//ADDED
Added Support for Multi Select
//REMOVED
Removed Slider gradients to prevent inconsistencies → Will maybe changed back soon™️
Download
Cosimo
September 18, 2021, 3:56am
Complimenti, ottimo lavoro
v1.0.3
//FIXED
Fixed read marker status inconsistencies
Fixed channel commander in compact server tree
Fixed drag and drop color inconsistencies
Fixed header gradients
//ADDED
Added dark theme variant
Added light theme variant
Added discover communities support
Download
Rikku
February 3, 2022, 5:27pm
7
Thanks for the greate update.
shdy
March 6, 2022, 1:43pm
8
Why is it getting flagged as a virus for me?
Windows Defender and McAfee seems to have a problem with this…
Thats normal because the installer is not verified by Microsoft or McAfee.
The installer source code is avaliable on GitHub if you want to verify the installer yourself: GitHub - LeonMarcel-HD/Colorful-TeamSpeak: a TeamSpeak 5 Extension
To install the theme you can either trust the installer or download the theme itself and unzip it into your extensions folder.
shdy
March 6, 2022, 10:19pm
10
I was just wondering because I could not remember that any installer I checked on virustotal was flagged before but it makes sense, thank you for answering
Hello!
Is it possible to contribute to this theme?
I’d like to adjust some color schemes (Green, Orange, Dark Red) and would either rename “Dark Green” to “Matt Green” or changing the color schemes there, too, as it’s not that “Dark” as the name says.
Also, what font are you using for those thumbnails?
You can edit the files as you like, but you should not reupload it. I’m fine if you use parts of the code, but then please credit me.
Font: Salvar Regular
v1.0.4
//CHANGED
//FIXED
//ADJUSTED
Adjusted overall color scheme || Dark Variant
Adjusted checkbox background color || Dark Variant
Adjusted toggle background color || Dark Variant
Adjusted number selection background color || Dark Variant
Adjusted identifier background color || Dark Variant
//ADDED
Added support for reply
Added support for edit
Added support for beta70
Download
v1.0.5
//FIXED
Fixed checkbox inconsistencies
Fixed drag and drop of sub-channels
Fixed chat bubbles tagging background color
Fixed activity triangle position
//ADDED
Added support for multi-chuck scrollbar
Download
Nu2ella
November 25, 2022, 5:21pm
16
Really cool thanks for making dis
v2.0.0
Note: Default and Light Theme are currently not supported and may not be updated
Download
soypora
January 23, 2025, 7:52pm
19
Cool, thanks for the update!
Kajoken
January 24, 2025, 4:34pm
20
Thank you for the update. Is there any way to change the big “Start your own Community” and the “Explore All Communities” boxes?
I’m not using a blue theme and those big blue boxes look very ugly compared to the rest.
