There are many Tutorials on YouTube, so please use Google.
So I go into my server and when I try to upload icons it says this https://gyazo.com/a7d310cdb9a6ed93bb2eb0d506e1ac05
Check that all necessary ports (TeamSpeak 3 Server - Necessary Ports) are open.
If you operate the server yourself, make sure that the file transfer port (30033 by default) is enabled.
Otherwise, contact your server provider.
If you are on Linux do ufw allow 30033
it is now an issue of this
they will not load
Make sure to open all important ports.
If it still doesnât work, make sure that it is assigned to the correct IP address and that the connection is not blocked.
Otherwise you can check the server log 0 to see which port is used.
moved by moderator
Hello everyone, I have a problem with the icons of the server groups, it happens that they load but they cannot see it, another person wanted to know what I can do to correct this error
What do you mean with they donât see them?
the image is bugged or it doesnât even appear?
hello if the image is loaded the icon but it turns out that I can only see it and other people can not see it, that is, it appears blank, what can I do because I would like to fix this?
The icons do not even appear in the load list the server is 32 slots
Hey, I am hosting my teamspeak 3 server on my VPS which has pterodactyl installed, I am having issues with uploading group icons, with the error: Transfer "icon_2859559792" reports: (could not open file transfer connection)
, All the ports are open, I even tried disabling the firewall and no such luck, If anyone has any ideas, I think it has something to do with Pterodactyl.
Thanks,
bzisniper
post moved by moderator
Whenever I try and and add an icon to a server group it says its not working.
What do you mean by preferences?? All I see is this.
Iâm referring to this part of the post
Eh okay, I just dont get it
Whoever hosts the server has not opened (forwarded) the port for file transfer.
Thatâs what he means.
i cant upload icons for server groups. i keep getting a âTransfer âicon_2177790619â reports: (could not open file transfer connectionâ error message. i read that i have to port forward but idk how to since i am not hosting mine.
Then you have to contact the server host to open port 30033 TCP. We cannot help you with this.
